Not sure exactly how to check that, but under battery it says 7h 29mins on battery - with Display showing 20% against it.
if you mean the timeout I have it set to 30seconds (was 15 on the SF).
spareparts tells all![]()
r12-modaco-modified
Can't use shootme as my phone isnt rooted....
Shootme is a terribly finicky app.
You should get a prompt from superuser when you launch it asking to allow or deny.
Try this one if you don't get anywhere: https://market.android.com/details?id=com.geeksoft.screenshot&feature=search_result
When I tried shootme on my older FLB rom they were upside down, did you not need to rotate them?
Looks nice and clean.
What time/weather widget is that?
recalibrated my battery.. we'll see how it lastsi haven't done the calibration after installing new ROM so no surprise really
