okaystulid said:You dont need any more than the CX430 for your spec.
3. How does the Asrock Z68 EXTREME4 compare to Asus P8Z68-V PRO Z68? (in short which one's better)
Thank you guys so far.
Last few questions (hopefully):
4. BeQuiet Pure Power L7 530W Power Supply, worth £6 more over the Corsair Builder Series CX 430W?
okay
3. Asus P8Z68-V PRO Z68 compare to Asus P8Z68-V PRO Z68? (in short which one's better)
They are the same board.
You edited the first question, get the cheaper ASrock, they are owned by ASUS too.
£35 more for the ASUS!!! not worth it.
What if there was £10 difference?
That changes things a bit, but from looking at the ASUS/Asrock homepage
http://www.asus.com/Motherboards/Intel_Socket_1155/P8Z68V_PRO/#specifications
http://www.asrock.com/mb/overview.asp?Model=Z68 Extreme4
There a Bluetooth adaptor included and 4 more phases on the VRM's
enough to go for the Asus?
