I have a rear disc on a 05 Clio 182 which appears to have not had the pin that the ABS bearing & disc slide on to greased. Either that and/or it's just rusted itself on to the hub.
Stolen from a guide:
You can see the hub nut in the center which wasn't a problem to get off, the disc however would not move for love nor money. 90 minutes worth.
I tried numerous methods to ease it off, hammers, prying with spanners, bars, hitting it in all number of ways, not even the ABS ring would shatter or crack so it's on there pretty good.
'Brake Pullers' seem to do the trick:
http://www.youtube.com/watch?v=m_rKwfOxFm8
The disc measures about 240mm in diameter. I've sourced a pulling tool
65MM REACH X 75MM SPREAD TRIPLE LEG REVERSIBLE PULLER
102MM REACH X 110MM SPREAD TRIPLE LEG REVERSIBLE PULLER
165MM REACH X 160MM SPREAD TRIPLE LEG REVERSIBLE PULLER
I'm not sure which reach/spread I need? or if 160mm is the maximum diameter disc it will work on?
Thanks,
BennyC
Thanks,
BennyC
