Bimmy Bimmy Bimmer!
It's not the interior I would have specced, but I don't think it's *that* bad! I'm not sure on the sport gear knob (what does the sport one look like?). Yes, the roof lining is anthracite.
I understand the sport knob was standard on all e46 coupe sports? It does feel a lot better than the horse penis knob when changing gears!
You got a link to this gearknob?
I've got the standard M sport gear knob (is this the same one as you are referring to?), but the plastic on the top of it is starting to come away.
You can pick them up off the bay for about £50 delivered. I even think the new Genuine BMW shop sells them.
The leather on mine is worn quite badly and the clips holding it on are broken so it sometimes comes off in your hand if you make an aggressive shift (which is the last thing you want when you're making an aggressive shift).
Anyone got a part number? There seems to be 2 or 3 different knobs. Want to make sure i get the right one.
EDIT:Nevermind, found it: 25117896031
Thanks chaps. The car is in immaculate condition, so (to me) it was worth the money.
Don't you like my brown knob? :p
I might change it if I get round to it.
It's the size of it, once you've used the Sport one, you realise just how much better it is!
