Well OCUK have got this - http://www.overclockers.co.uk/showproduct.php?prodid=HD-014-OC&groupid=701&catid=14&subcat=910
Get the OS and about 5 games on it.
That is the best you will get for under £80.
If you can expand your budget to £90 then you can afford the next gen of the same make - OCZ Vertex 2E
This only boasts significantly better write speeds, read speeds is similar, so it may not be worth it for you, but it's the only other option you have probably, even if it is an out of budget option lol
That sounds like a bit of over kill to the drive? Would running at almost full capacity not cause the drive problems?
Well any drive running full would have its performance effected would it not?
SSD without TRIM are like years ago.
No.
Aslong as the SSD has TRIM theres no performance issues anywhere.
fair enough, I had just thought running a disk which is almost full killed its performance, something new i've learned then. Thanks![]()
