Looking for a new SSD.
That is the best you will get for under £80.
If you can expand your budget to £90 then you can afford the next gen of the same make - OCZ Vertex 2E
This only boasts significantly better write speeds, read speeds is similar, so it may not be worth it for you, but it's the only other option you have probably, even if it is an out of budget option lol
Meaningless, write speeds and read speeds quoted by manufacturers don't mean a thing.
120GB Vertex vs a 120GB 2E - http://www.bit-tech.net/hardware/storage/2010/08/17/ocz-vertex-2e-review-120gb/3
Its not worth the extra really.
Aye, but that's just the sequential read and write of uncompressable data, if you look here the random read and write of the Vertex 2 is significantly higher than the vertex 1 and imho worth the £16 price premium.
That sounds like a bit of over kill to the drive? Would running at almost full capacity not cause the drive problems?
Why? what you heard?
never seen any warnings about,
"oh its 60GB capacity, but don't fill it up"
I thought that was before Trim? Where filling a drive could have consequences i.e. degraded performance, probably imagined that though.
SSD without TRIM are like years ago.
even then it wasn't the capacity usage, it was the usage of each individual memory cell over time that degraded as each cell wasnt cleared before a re-write.
