- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys,
We have a new product from Scythe - BIG IS BETTER!
Scythe Susanoo High Performance System/CPU Cooler (Socket LGA1366/LGA1155/LGA1156/AM2/AM2+/AM3) @ £79.99 inc VAT
The Susanoo Scythe CPU cooler consists of a total of twelve 6mm heat pipes and features a two segment heat sink configuration called DBS (Double Block Structure), which provides a massive cooling area for a top-flow CPU cooler. Thanks to the large cooling area, the surrounding components such as MOSFETs, Northbridge, RAM and graphics card can be cooled simultaneously. The Scythe Susanoo CPU Cooler is equipped with FMSB3 (Flip Mount Super Back-Plate 3) to ensure secure mounting on to the motherboard.
- Cools the CPU along with motherboard components
- Massive cooling area
- Features 12 heatpipes!
- PCI fan controller supplied
- Requires plenty of space for installation
- Socket LGA1366, LGA1155/6, LGA775, AM3, AM2+, AM2 compatible
- Fan Speed: 500 - 2000 RPM
- Fan Noise: 9.42 - 37.69 dBA
- Air Flow: 50.05 - 200.21 CFM
- Weight including Fans: 1565g
Only £79.99 inc VAT.
ORDER NOW
Here are a few camera snaps showing it against a bottle of coke.
ORDER NOW
