Just to explain
The side fan takes cold air from the side
The fan over the gcards blows directly onto them and can hit 1200rpm and 140cfm
The front fan on the HAF-X draws cold air in
The HDD heat output is negligible and they are hardly used
The two 120mm fans that sit just in front of the gcards take cold air from the front and blow over the GPUs and toward the rear
This is necessary for the 6990 at the top - see the heat image below
The top fans extract and the fans on the H70 are 1900rpm Scythes - hitting 1900 on full load - extract also
The temps of the 6990 have bee improved with this setup. The 6970 temps have been reduced also
At i42, we had some guy with a thermal camera
Before introduction of larger side fan and front 120mm fans
From the above, you can see temps of over 85degC!!!!!!!!!!!!!!!
After I used a large 140mm side fan at 1200rpm/140cfm max and also two front 120mm fans blowing over 6990 and 6970
Idle
Load under Heaven 2.5 benchmark for 3 minutes
Again, temps have come down dramatically. A good 20degC when loaded
