Co-op have jsut started rolling it out too.I've not heard of this calculator approach with online banking before. Which banks implement this?
snip
I don't believe that the PINsentry machine know the time/date in a precise enough way for it to be valid as a security system.Being a Barclays employee this thread has made me grin quite widley
I once convinced someone they did actually work on radio wavesWhich is totally untrue.
The question regarding the devices in branch and at home..... it does not matter which device you use or where, they are all programmed with the same algorithm. In fact, you can use any banks reader with any other banks card (although the technology was developed by Barclays), so if your partner banks with NatWest and you cant find your card reader, you can use thiers.
It is very, very, very clever and indeed links your card number (and amounts and account numbers for making payments) to the time and date you request the code to generate your authentication code to repeat back to the system, which runs the same calculation, all of course having been verified you are in possesion of your card having used your pin number to generate the code. This is why you need to input the last 4 digits of your card when you log in, so that it can match your username to your bank record and then from your record it can tell which card you are using.
We use it in branch simply to identify you - just like using chip and pin. We use the response code to "log in" to your account, just like you use it to log in to online banking - exactly the same theory.
I see, makes sense.
How exactly does time factor into seeding the hashing function? If it used discrete measurements (i.e. right down to the second) then obviously when the bank carries out the same calculation it will produce a different hash. I'd be amazed if it is 24 hours.
I see, makes sense.
I don't know about the validity of that but what I am saying is that although the PINsentry might be really secure, I am highly sceptical that it works on a system that relies on the time being known by the device itself. For a start, what kind of cheap mass produced device can keep any semblance of accurate time for 7 years (the stated lifespan of the device on one battery). Secondly, if I take the battery out and reset it, it still works fine. How does it keep the time without a battery?Interesting. Would you believe it if you were to know that since its introduction online banking fraud has been almost irradicated?
snip
Probably some on-board supply just for the system clock.
I can assure you it is true. There will never be zero fraud - People will still get burgled who have thier usernames and pin numbers written down and kept in thier wallets with thier cards etc, but fraud cases for old style online banking fraud has literally vanished.
In relation to the second point, I do not know the answer, but it is probably something simple. Maybe an elecoornics guru can make a suggestion.
Considering this is a device that works with a C+P card, are we sure a C+P card has no way of telling the time?
