Just ordered 4 new tyres
Because the only reason to run larger rims is for bigger brakes, and wider wheels allowing for softer rubber
Yeah totally.
That's why the BMW F10 M Sport comes with either 19s or 20s, even though the brakes are the same as on the SE, which comes with 17".
lolrypt
you keeping your insignia now dave mate?
Probably.
I've decided to do the garden myself, I have 2 weeks off soon so will do the garden and floor the attic in that time. If someone came and offered me £18k-£20k for it then I would most likely let it go. It would be nice to have the money for various things & buy a cheaper car. However, I say that now, but as soon as I sit in the car & turn the key I decide I could never get rid of it :p
[TW]Fox;19194364 said:
I personally dont like enormous wheels and will be repacing the 19's on my next car with 18's
If it's for ride reasons, it's much less noticable on cars fitted with Dynamic Drive.
But I don't think your next car will be an F10 just yet :p
Do they do a staggered width setup on 18s?
If you're referring to BMWs, then yes.
It's possible on some 17s, like on my Z3. But it almost always is on 18"+
Yeah totally.
Purely for bling reasons then I guess as if you aren't using larger brakes then there is no need for wider wheels for softer rubber.
Also the 20's are forged. I dont have to worry so much when hitting potholes (although I obviously avoid most of them).
Great .... no practical reason why Vauxhall could not offer forged 19s (other than trying to create a market for bling 20s)
You can run a softer rubber compound on a wider wheel and experience the same wear rate as a more narrow wheel with a harder compound
So if I buy 2x CS3 245/40 for the rear and 2x CS3 225/45 for the front of my BMW, the rear tyres will be of a softer compound?
Forged alloy is more about lightness than strength. Yes it's stronger, but that is usually counteracted by there being less of it. That's why it's often used on more adventurous alloy wheel designs. The strength rarely ends up being hugely ahead of normal cast alloys. So yeah, you'll still want to dodge those pot holes.
