can someone point em in the rite direction plz.
When i try to validate my under overclock on CPU-Z it keeps coming up with my pervious overclock of 5.1ghz, How can i get so i can validate
my score with out it showing my pervious score?.
Thanks
I was having the same issue, re-installing CPU-Z sorted it for me
TV will rot your brain. Stare at a PC monitor instead.
Oh wait they are the same....
here are scores and links
3d mark 06 score
If i have missed something out could you let me know.
Thanks
Something you may have missed is that the aim of the 3D mark 06 part was to get as close as possible to a target CPU figure? In the 1155 socket case that's 7604. Given that you are above that figure you should be able to find some way to slow your rig down to get closer....At the risk of you beating me...Something you may have missed is that the aim of the 3D mark 06 part was to get as close as possible to a target CPU figure? In the 1155 socket case that's 7604. Given that you are above that figure you should be able to find some way to slow your rig down to get closer....
LMAO, I missed read that then, lol...
