I'm not sure if Dial-a-wash are really considered a detailer.
At a guess, at least they are insured?
Who says I won't be?
And what is a paint system supplier, it sounds like you are spraying cars with their products or possibly using their products!?
If the latter is true then surely I could pickup 3 tonnes of 'Zmymeow Essential Virgin Body Microgranular Paste' and claim to be a preferred client.
I've sat back and read most of this thread and now have to post.
Mike, good luck with your venture. But keep your outgoings to an ABSOLUTE minimum to start with and until you have a large client base. Now you're on about premises. This sounds like it's going to be very very expensive when you haven't got guaranteed work.
Mike,
Sounds like a lot of equipment your planning on buying or do you have this already?
Shouldn't you be buying this stuff after you've turned over a good amount of money to invest back into the business?
I assume you have completed some market research and aren't just getting a bit excited in what your buying before its actually required?
Id be worried about the reliability of any 3k VAN. If your charging several hundred pounds per job (which i guess you are) shouldn't you be looking at extending your budget a little, for something reliable? I'm not 'ofay' with tax rules but my brother who runs a roofing company changes his work van every 3 years because he can only claim tax back on a 3 yr old van? or something along those lines. I'm not 100% sure on this ^^.
Unless you plan on running to your clients with your water tank/generator/cloths etc id be upping the budget slightly.
I'd guess at "paint system" being a stepped technique, each with it's own product. Unless it's a paint application system used in a bodyshop which seems a bit much to start off with.
If it were me, I'd be looking at the sealants like Wolfs, Nanolex and Gtechniq...I'd plump for Wolfs personally. Everybody likes the idea of a pin sharp, easy-to-care-for and super durable finish at a good price and I'd guess that market is far bigger compared to clients who want premium carnauba offerings.
in the early stages the need to keep outgoings as low as possible far outweigh this.
With £3k, I could lease a van for a year. It has nothing to do with lack of cash, but rather aiding success of the business by removing potential hurdles.
