- 14 Sep 2010
- Port Talbot - Wales
If the above is possible, i have to admit, it balances the look of case as it smoothes the lines and overall look of the case - plus it seems more in keeping with your original concept of the over all aesthetic appearence.
If it's possible, personally, i think its a subtle and classy improvement - but if it's not possible i'm sure you'll find a suitable compromise.
Great updates as usual - really enjoy and admire your endevours - keep it up.
+1 that looks good IMO
Maybe make the strips go right out to the edges of the case so it looks like it's just held in place by the side pieces, not by 'a piece bolted to the side pieces' if you get me...
I'm thinking of a full length bar about the size of the copper tabs legth wise with bevelled edges going straight to the bottom of the material so it fills the hairline gap between the acrylic & alu so still has the flush fit appearence, it's a bit difficult explaining it properly lol
LOL
