Project Stealthlow
The inlayed alu is better than the pyramid in my opinion (although I'm not 100% sure where these are going).
I am still of the opinion that even without the tabs and the copper stays you have enough copper. I do like the copper vents, but personally I'd stop there with the copper otherwise you will detract from those highlights.
This is too awesome! attention to detail is unbelievable and the level of skill + sheer number of tools is pure awesome!
:D Thanks mate, yeah the tools have been building up over the time I've been into making cases, could still use much more if I had the money :D, started off with just a couple of basics just glad I have access to a garage to do this stuff :cool:.
They'd have been for the tabs instead of too much copper by a single chunky bar of copper, it's with quite a few saying the full length bars look better, but still I think I'll re-do the tabs that stretch across the case with something more fitting & make my mind up from there ;), thanks for the honest opinion John appreciated :).
Don't get me wrong, I think what you have done is a-m-a-zing! I do like the inlayed alu on its own, but I am still concerned that more copper will detract from the feature copper you already have. I guess I will have to reserve judgement until you replace the tabs...
Looking forward to that!
Thanks man, yeah I've recognised too much copper & it doesn't look to good, it's proving to be a difficult ballance to get the ratio spot on :D.
Well rested & back on form, shame my tools aren't :duh: decided to give the copper bars another shot but with a strip of alu in the middle like in the concept pics I shown earlier, got 1 of the copper strips straightened back out.
Here I am getting the centre of the copper bar aligned with alu flat bars clamped in place to stop it moving around, I did clamp extra bars on top to hold it in place properly vertically too but it made it so the copper couldn't slide through, anyway it all went wrong because of the crappy drill table moving up or the chuck letting the mill bit move down & ended up milling all the way through the flipping piece grrrr, think I'll accept I can't mill good with a cheap drill press now :D.
The main problem is getting the correct depth when doing this, takes ages to set the depth & for it to stay there, I tightened it all up good & proper but still just wasn't enough, mills are way too expensive for me so next best in line is a router.
But I can safely say the full length copper pieces will not happen on this, I tried with what I've got & failed so I'll keep working on tabs & reserve the copper for something else.
Just taking a quick time out to post this, then I'm getting back onto it :D.
Wow that looks very labour intensive. Full marks for trying it though!
I agree that this isn't the way to go, but don't you have a stop on your drill? That way you couldn't go too deep.
:D I don't use the plunge when doing this so have to set the height manually by getting it spot on & then tightening it up, looks like the mill bit came down a touch while doing it so it's a no go :o.
Didn't get to do any more on it today, garage got taken over :D, but was sunny again so took a couple extra pictures :D, also flipped the copper mesh around & think it's more fitting with tiny countersinks so matches the other front vents better, so will need to make a new eject button hole.
I've said it before and I will say it again. Incredible craftsmanship! Really impressed how you have kept going with this. I would have got bored/distracted many moons ago.
Thanks ch3333z :) lol yeah I've been seeing some awesome games get released & would have really liked to get stuck into a few but I'm keeping that as 1 of the motivators so I can play them in a sweet new case but I think I'm going to have to ignore AMD & intel & nvidias offerings of awesomeness on the next wave of tech :D I really could have held out to see what AMD are bringing but I may feel ok if it doesn't do a lot better than sandy bridge :D but if it does oh dear :( lol.
I even passed up on the steam sale last christmas so I could put the money towards a new rig to put in this lol but yeah I should have held out on the tech, D'oh :D, but at least I'll have a smooth transition putting an up & running rig into it ;).
Ouch!
The photos in the sun really tone down the copper, making the tabs much more pleasant, although my eye is still drawn to them which I think is undesirable. I think partially this is down to the colour, but partly it's the shape. I wonder what a triangle, or better still perhaps something curved to match the rest of the design. Perhaps some S shapes?
You might be able to do the same for the cross bars, although that might be a nightmare to get the right shape. I wonder if they could be replaced by something transparent such as another piece of perspex?
Having said all that, what you have done is truly amazing and inspiring.
Fantastic job you've done!
My own constructive crit: I quite like the colour contrast myself kinda steampunk, but I'm admittedly not a fan of either the tabs or the shape of the vents. If it were me I would have had a single large vent above the optical bay slot (fan behind it sucking air in) and left the rest of the curve unbroken. With the tabs, and the bars, I think it's the fact they clash with the sweeping vertical lines of the front/sides of the case by being so obviously horizontal. My 2 cents.
Ouch!
Thanks John, I can seeing it taking a while before I figure out something that looks good & functions good with the window clamp so it's gonna be a whole new PITA chapter of the project :D.
Thanks Somnambulist yeah it's not gonna be a quick solution making it spot on, I am confident it'll get there but when I'm not sure at all :D.
Gonna have to drill & bung a thread insert into the clamping piece inside the fretsaw, it will not tighten up so the blade is very slack so it's only any good for thin or soft materials & even then can pop out quite easy so I'll need to find out the thread size so I can maybe even make my own, the blade keeps popping out when cutting thicker metal, so irritating.
Made a few tabs out of 5mm acrylic but prefer the copper so wasn't able to make a few with the fretsaw & my hacksaw died a bit ago which just leaves the jigsaw or manual fretsaw as an option lol grrr, manual fretsaw the blades keep breaking very easily (I must just lack technique on using it like any new tool) just not as good as a powered one for me, with the powered one I could effortlessly cut how I wanted on the line & I just can't with a manual one without a heap of practice.
Finally got around to re-painting the pci/io piece with the far better copper spray :D & think that's the best news in this update lol.
And here is the vent meshes showing what it looks like with the small copper tabs & acrylic tabs but while I don't prefer the look of the full stretch tabs I just can't ignore they do what's needed which is to keep the panels at the same level all along the full length, they will be re-made so they haven't got the un-needed extra countersunk hole, might even thin them down in the middle so they don't stand out as much.
There is however another way to keep it so the window is held in place nicely & that would be to add a couple more tabs just below the vents but it would put the spacing out a bit.
Or even JB weld the internal tabs in place & just go & do full length tabs so it's easier to install & remove a full length tab.
I'm getting way too indecisive about what I'm doing regarding the tabs, it's just not fun modding, would have probably completed this by now if I chose to pass on the full length strips.
I'm sure the sudden increase of heat isn't helping neither, I tend to mod best in the cold, keeps me more alert & not slouchy, been 1 of those days where I'm lingering in the garage thinking what on earth should I do :confused:.
I'm not keen on using adhesives but might make an exception this time.
Had a thought & it might be a good one or bad :D, since seeing JB weld getting used a bit lately, I wonder if it's possible & what would happen if I layered strips of 1mm alu & 1mm copper on top of each other if it would stay firm when removing the main curve bars & avoiding the need to use bolts, could give it a very clean look or it could just fall apart when removed, I just don't know, there is a bit of force in the window & the curve bars which is a part of what keeps it all strong so layering up while it's in this form maybe it could make it keep the form when removed, either that or the adhesive on the stuck on bits would just crack & pop off lol & I'd be gutted :D I'd put a strip of 1mm alu on the inside too.
I do think if the adhesive is up to the challenge it could work well but could use a little feedback if you think it could do it, I checked out with google to see how strong it is compared to welding & some say it's about 30% of the strength of the material while welding is just as strong & the 30% is only when the material is prepped properly, I wouldn't be able to smother it on neither, wouldn't want it to squeeze out making a mess so just enough to let it get stuck well, I'm thinking for the top layer it would be a minimal strip of the adhesive to stop it making a mess.
If that was to work well I'd be able to remove the whole lot as 1 piece by unbolting at the top rear & bottom front, but that would be putting a lot of faith into the strength of the adhesive though.
What do you guys think? is JB weld good enough for this?.
Not used JB weld but have used Liquid metal, a very similar product and found it to be very strong. it's essentially like a bathroom sealant in application so you have to make sure you use the right amount or just tape over the area where potential ooze could go. Failing that just wipe any ooze off before it sets.
I'm also not a fan of adhesives, as they are pretty final but sometimes you have to use the tool at hand.
by the way, I like the copper paint. Is it is as nice as it looks on photos.
I'll probably try that & JB weld to see which does the job best, I'll run a couple of tests to see if it would pop off when released from the tension, those big dispenser tubes I think I'd put some on a palette & use it from there, always seem to squeeze way to much out when using those lol :D & of course I'd scratch up all the surfaces that will be stuck down for a better grip ;).
I'll see about the paint when I go over to check it out but it sure looked way better than it did :cool: was very impressed with how it looked quite like polished copper, does need a really smooth surface for that though.
So while I wait for a few bits to arrive I'll start on the fan cable system, most the upper ones will need extending, all will need sleeving, then routing & hiding, then I think it's just a matter of getting the fan mount bars painted & getting the full tabs done & I think it will be complete & ready for putting hardware inside it woo hoo :cool::D.
Thinking a good strong silicone might be the solution for mounting the strips :).
PCI/IO in better copper paint, plastikote brilliant metallic copper, not a perfect match but not far off at all :) & as you can see got a bunch of bolt heads painted in the process of protecting the threads :D.
With it installed back into the case & some close ups.
Now, time to work on the hdd cage platform fan wire stash pass through gaps & the little copper bar in the picture is for the optical tray :).
Took a break to get something to eat & get the log up to speed :) after posting this I’ll get back to a big filing session :D.
And thought it looked pretty cool on it's side so took a couple extra pictures lol :D.
:eek::eek::eek:
that case is epic :D
Are you going to leave it two tone? Looks good imo
edit: free shipping y0! :D
The beast has been leveled!! lol
Looks strangely unsettling seeing it laying down - looks vulnerable, or injured :(
Stand it up again, it's making me sad :( lol
:eek::eek::eek:
:D Cheers mate, yeah I decided to keep it raw metal & only paint bits that I had to use body filler on :) my local anodising place doesn't acknowledge emails :confused: if they did it would have been black externals & copper internals but I've grown used to the idea of keeping it raw & like it :D.
Lol :D here we go with the rise of the beast then, was just resting :p.
Continued until 01:20 AM :D so I'll have to get a router for future mods it was a silly amount of filing to be done & didn't have my thinking cap on as I should have drilled it a bit to make it a little easier :o.
Wow for something so simple sure took a lot of energy to do lol, sweat pouring off me too so had to get a cold one :D which made doing it less dull :D.
So now the cartoon mouse holes are done for the fan cables so I can work on the extending & then sleeving of the fans while I wait for a couple more things to arrive for a couple of extra touches, super close to the finish now I think :) also used the disc sander to shave a bit off the hdd slide mounts so the cages go in & out a little easier :).
All back together :).
Not sure if I mentioned it earlier but I ordered a 1mm sheet of copper for doing the full legth tabs :cool: + ordered a mirror polished stainless steel sheet, just enough to cover the 2nd level for less than a tenner woo hoo :D.
The attention to detail in this build astonishes me every time I come back to it!!
Look forward to seeing the new full length tabs :)
(technically they can't still be tabs if they're over 3ft long can they? More like rails? What d'you reckon?)
