What kind of network throughput are you guys able to get on yours?
I've now tried ESXi with WHS2011 and Ubuntu Server as VM's and also a native install of Windows 7 x64 to compare against and each time my network transfer speed is rubbish (30-50MB/s usually dropping off to about 14MB/s towards the end). I also updated the NIC driver in the native install of Windows 7 to the latest available from Broadcom as HP's drivers seem to be about 2 yrs out of date.
I've done some tests on the RAID5 array and that can easily hit 250MB/s write and nearly 300MB/s read with 4x 2TB WD Green drives in the array. Controller is P410 with cache and battery module. Internal file transfers between different physical LUN's are fast. No problems there.
Next step is to try and source a compatible Gigabit NIC (pref Intel) and see if that makes a difference. I know it's not just me as my boss also bought a Microserver after seeing mine and is looking at the native install route and is also struggling with getting any decent network throughput.
If you're able to hit and sustain 100MB/s or more, could you list your hardware and software config for me? Thanks.
