- 3 Jan 2009
- Bedfordshire
How do i know if trim is on?
Have i got to turn off defrag?
Os is Win 7
Thanks
Os is Win 7
Thanks
That doesn't tell you if TRIM is working, it merely tells you if Windows is passing TRIM commands, which, as I said, it will by default.
Windows 7 will pass TRIM by default. As long as you're using TRIM compatible drivers (e.g. default MS driver or Intel RST), your SSD is TRIM compatible and you're in AHCI or IDE mode, it should be working.
Note that some SSDs only work with TRIM after a certain firmware version so it's probably a good idea to update it to the latest version available.
Intel RST drivers will pass TRIM to an SSD if your SATA controller is set to RAID, as long as the SSD itself is not in a RAID array. Since you have an ICH10R southbridge, you can use Intel RST drivers.What if the BIOS is set to RAID (since I will have 2 F3's in RAID 0)? Will TRIM work with RAID mode set in BIOS? (the SSD wll not be in RAID, only the F3s)
