I've given up for 5 months now, but I’m still using lozenges sparingly.
This is my third attempt. Previously I've started again after about 6 months after foolishly thinking a couple at the weekend wouldn't be a problem.
The stupid thing is I'm feeling the same way now. Must resist![]()
I've never even put a cigarette to my lips. Where's my praise?
If you google e-cig or better still go to cloud9vaping.co.uk or libertyflights.co.uk you can read all about them
PV is a battery tube or box really, attys are atomizers which heat the juice up to create a vapor, cartomizers are the same as atomizers but filled with a media which absorbs juice and leakes it to the atty.
I too smoked a long time .....from about 11yo i'm almost 50 atm
@Bri62, many thanks, will bookmark those pages and have a shufty through them tomorrow, cheers mate.
Its called a "Provari" no its not a passthrough runs of a single 18650 high drain 1600mah battery.
I get between 10 and 12 hrs use on a charge @ 4.4v atm
