Need your help !!
I've read a few forums where a flashing blue phase light on the C45 means a power supply issue but if that's been checked with a multi-meter for all the voltages, then everything else seems to have been ruled out apart from the CPU.
Exactly, i'll be requesting an RMA to be opened to have my CPU replaced ASAP i think :)
I'll post back as soon as I hear anything from overclockers :)
If you phone them, you might want to explain and send the memory, mobo and cpu to them so they can check it all together, two broken mobo's in a row has been known even if it is unlikely, just you wont want to get a new cpu and if the problem still exists then we are back to the start again.
