Have got a spec in here please approve
27 Sep 2009
INTEL CORE I7 950
GIGABYTE X58A UD3R
ATI 5870
CORSAIR 850W V2 PSU
FRACTAL DESIGN GREY R3
SEAGATE GREEN 2TB
BE QUIET DARK ROCK
KINGSTON 4GB HYPER X. (Shall i go for 8GB in case prices shoot up)
ASUS XONAR DG
SONY DVD-RW
A FEW NZXT BRAIDED CABLES
Fell free to suggest other parts.
Rig will be used for gaming and browsing
Where to start..
Drop the 950 and mobo and get SandyBridge 2600k.
Green HDDs are slow, designed for low power storage, not a gaming PC. Get an SSD.
5870 is a little old, might consider a 570gtx instead.
Where to start..
Nevermind the fact a GTX570 is double the price ;)
MSI GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card £239.99
(£199.99) £239.99
(£199.99)
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor £173.99
(£144.99) £173.99
(£144.99)
MSI P67A-C45 Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION ** £89.98
(£74.98) £89.98
(£74.98)
Fractal Design Define R3 Midi Tower Case - Titanium Grey £84.98
(£70.82) £84.98
(£70.82)
XFX Pro 750W Core Edition Power Supply £72.98
(£60.82) £72.98
(£60.82)
Corsair XMS3 4GB (2x2GB) DDR3 PC3-10666C8 1333MHz Dual-Channel (CMX4GX3M2A1333C8) £44.99
(£37.49) £44.99
(£37.49)
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £43.99
(£36.66) £43.99
(£36.66)
Corsair A50 High-Performance CPU Cooler (Socket AM2/AM3/LGA775/LGA1155/LGA1156/LGA1366) £27.98
(£23.32) £27.98
(£23.32)
Samsung SH-S222AB/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM £16.99
(£14.16) £16.99
(£14.16)
Sub Total : £663.23
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £13.75
VAT is being charged at 20.00% VAT : £135.40
Total : £812.38
Made a sandy bridged build around the £800 mark but without a real budget its a bit difficult. As above suggested, SSD would be good
Where to start..
sorry for the stupid question but does the 570 gtx do direct x 11. Sorry if its a stupid question been out of the loop for a long time
Ok I have this spec trying to get it below 800 but i thinkthis is as far as i can go
MSI GTX 570
INTEL CORE I5 2400 3.10GHZ
MSI P67A C45
FRACTAL DESIGN R3
XFX PRO 750W
SAMSUNG 1TB F3
KINGSTON HYPER X 4GB GENESIS GREY
BE QUITE DARK ROCK COOLER
DVD -RW
CREATIVE AUDIGY SOUND CARD
Any issues with this build..thanks
Loose the silly expensive cooler and get the K series of the chip - means you can overclock it.
This:)
Sandybridge runs quite cool so I'd suggest a Corsair A50 or Gelid Tranquillo.
Probably don't need the soundcard too unless your big on your audio!
MSI GTX 570
MSI P67A C45
FRACTAL DESIGN R3
XFX PRO 750W
SAMSUNG 1TB F3
CORSAIR A50
DVD -RW
comes to 768
Im not going to get the k series as i never overclock
on the msi boards there's a feature called oc genie which on the GD65 (possibly 55 and 53) there's a button that you press which gives you an instant overclock of about 4.2GHz. on the others its either a function in the BIOS or you run a program through windows, not sure which one, and it does the same thing, just without the button.
