I'm a bit out of touch, could somebody spec me?
18 Dec 2005
Londontown
Hello there,
I'm currently plonking away on a system from 2005;
1.8ghz Opteron 165,
2gb of RAM
NVidia 9700GT
500gb WD HDD
74gb WD Raptor
... And a whole host of other outdated crap, sigh!
I've come into a minor amount of cash and am looking to spend £400 - £500 on a system (have a monitor, a lovely 22" Dell IPS panel) and the rest.
Just wondered if anybody had some spec suggestions as I'm a bit out of touch with it all these days! And, on a side note, am looking to get a small-ish case, I am exceptionally fed up of my gigantic Antec P180 tower!
On another side note, any idea how much I might get for my current set up? Maybe £150?
Cheers,
James
You got any SATA HDDs or DVD drives you can keep or you looking to sell it as a whole?
Oh and what are your main uses? Gaming? Video/image/audio editing?
Yeah, have two DVD drives and two SATA HDDs, can easily keep them. Quite content to just break my rig up and sell each part.
@Cookeh - Not a lot to be frank, I used to game a lot but not so much these days, just need something that will play HD video alright and well, that's about it! I don't do any photo/video/audio editing of any type so don't really need a CPU powerhouse
Not bad, the HDD will be slower than a granny out for a sunday drive though!
GT430 is about on parallel with the onboard in the spec I linked tbh :p
This would be another alternative, with HD3000 onboard graphics - will cope with older games at a medium level:
YOUR BASKET
1 x Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor £173.99
1 x Silverstone SST-SG06B Sugo - Black (with 300 W PSU) £93.98
1 x Asus P8H67-M Intel H67 (Socket 1155) DDR3 Micro-ATX Motherboard - (Sandybridge) ** B3 REVISION ** £84.98
1 x Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £43.99
1 x OCZ Platinum 4GB (2x2GB) DDR3 PC3-10666C7 1333MHz Dual Channel Kit (OCZ3P1333LV4GK) £29.99
Total : £438.94 (includes shipping : £10.00).
Or, you could get this:
YOUR BASKET
1 x Sapphire ATI Radeon HD 5830 Extreme 1024MB GDDR5 PCI-Express Graphics Card **OcUK Exclusive** £99.98
1 x Asus M4A88T-M AMD 880G (Socket AM3) PCI-Express DDR3 Motherboard £59.99
1 x AMD Athlon II X3 Tri Core 450 3.20GHz (Socket AM3) - Retail £59.99
Total : £399.92 (includes shipping : £10.00).
Capable of playing BF:BC2 at at least high - so will certainly cope with the odd game :)
I would swap the PSU with a XFX Core 550W.
'Green' drives are slow, which maybe fine depending an what you want to use it for.
Not sure what kind of games you are planning on playing, but the GT430 is really low range.
YOUR BASKET
YOUR BASKET
The Sugo PSU wont cut it with a 5830. Just too much power, they draw almost the same as 5850's.
