BEST UK PRICE! ANTEC HIGH CURRENT GAMER 620W PSU - £49.99 INC. VAT
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
At only £49.99 inc VAT, this is truely the choice of champions for any single GPU PC system.
Antec High Current Gamer 620W Power Supply @ £49.99 inc VAT
Antec’s High Current power supplies are the perfect PSU combination of power and efficiency. The High Current Gamer features a high-power +12V rail and special heavy-duty High Current connectors and cabling that supply extreme levels of power, and also superb efficiency thanks to 80 PLUS® Bronze certification and Active PFC. Highest-quality gold-plated connectors, Japanese-brand capacitors and quiet 135 mm double ball bearing fans complete the package. If loads of power, High Current engineering and extreme efficiency are what you’re after, the High Current Gamer is the PSU for you.
- 80 PLUS® Bronze certified – up to 88% efficient
- High Current +12V rail for graphics card compatibility and over
current protection (OCP) for safety
- Quiet 135 mm double ball bearing cooling fan
- All Japanese brand capacitors for reliability
- Gold-plated High Current terminals for optimal conductivity
- ATX12V version 2.3 and EPS12V version 2.91 compliant
- Full industrial-grade protection:
- Over current protection (OCP), Over voltage protection (OVP), Short circuit protection (SCP), Over power protection (OPP)
- Active PFC with PF: 0.99 – less harmonic pollution and more
savings on corporate electrical bills
- MTBF: 100,000 hours
- Meets 2010 EUP requirement: 5Vsb < 1W
- Safety: cUL, TÜV, CE, CB, FCC, C-TICK, CCC, BSMI, Gost-R
- Weight: 4.4 lb / 2 kg
- Dimensions: 86 mm (H) x 150 mm (W) x 160 mm (D)
Only £49.99 inc VAT.
ORDER NOW
That's an incredible price. I'd get it if I needed a PSU that beefy. A deal on the 520W on the otherhand... maybe too enticing.
You can say that, but It's seen about 7 years of use. 4-5 of them as my psu in a machine overclocked as much as I could. And it survived a chest high drop. I'll be sad to see it go if I'm honest.
The hypers are good units, however if one develops a fault they tend to take out the motherboard, CPU and sometimes the GPU.
A risk I would not want to take.
Ordered one last night after realising that my current 750w psu will probably just catch fire and take out everything else when my current upgrade comes together.
When I bought it last year I wasn't anticipating such an upgrade for a long time (if ever) and not being too clued up on PSUs thought that 750w was 750w :o. I needed a cheap replacement straight away.
Looking forward to getting this fired up!
What brand are you using currently?
