 - 8 May 2011
have phenom x4 840 and gigabyte m68mt s2 mobo everytime i put oc it it boots but resets cpu to stock speed help please
no when you press CTRL F1 it brings up advanced chipset settings and changed fsb to 205 booted fine but it had reset to default :/
Possibly a 5MHz overclock is too much for it
You really need someone with this board to give you a hand.
 mostly 7-8 but had it 6 on core temp
yh ikrmostly 7-8 but had it 6 on core temp
You don't seriously believe those temperatures do you?
All modern heat sinks come with a little gizmo that bleeds heat into the ether. You aren't seriously still running above ambient temperatures, are you?![]()
