As a minor follow up, I've just flashed the BIOS on my other MicroServer, and things are looking promising.Cheers bud I look forward to some testing
Links to the hacked BIOS and firmware with instructions here: http://forum.wegotserved.com/index....roserver/page__st__124__p__104539#entry104539Do you have a link to the bios you've flashed to?
What kind of network throughput are you guys able to get on yours?
I've now tried ESXi with WHS2011 and Ubuntu Server as VM's and also a native install of Windows 7 x64 to compare against and each time my network transfer speed is rubbish (30-50MB/s usually dropping off to about 14MB/s towards the end). I also updated the NIC driver in the native install of Windows 7 to the latest available from Broadcom as HP's drivers seem to be about 2 yrs out of date.
I've done some tests on the RAID5 array and that can easily hit 250MB/s write and nearly 300MB/s read with 4x 2TB WD Green drives in the array. Controller is P410 with cache and battery module. Internal file transfers between different physical LUN's are fast. No problems there.
Next step is to try and source a compatible Gigabit NIC (pref Intel) and see if that makes a difference. I know it's not just me as my boss also bought a Microserver after seeing mine and is looking at the native install route and is also struggling with getting any decent network throughput.
If you're able to hit and sustain 100MB/s or more, could you list your hardware and software config for me? Thanks.
Is anyone else who's able to get 100MB/s or more on one of these Microservers using Western Digital Green drives?
Sorry for the long post, but I've spent a week on this now and am starting to get a bit fed up with it and desperately need to find a solution.
Simpic, have you managed to get both the eSATA and internal ODD SATA ports working at the same time (i.e. you have six SATA drives)? In the thread you link the author connects an eSATA to SATA cable up and ponders using it for a cache drive but, frustratingly, never attempts it.This is how I have mine set up with the 2.5 inch HDD on the esata connection. All running at full speed.
http://www.avforums.com/forums/networking-nas/1429720-tims-7-24tb-tiddler-unraid-nas.html
Very useful BIOS instructions.
This latest BIOS was only released a few days ago on the 27th May, so it might be a little while before a hacked version crops upAnyone have a pointer to an AHCI version of the latest bios dated 02.04.2011?
I've now run into the roadblock it seems a few people here have. Despite having flashed the BIOS, disabled SATA combined mode, etc. I can only get the internal ODD SATA to work. I get no response from the eSATA port at all.
Looking ahead to plan b, does anyone have any experience adding a cheap-as-chips 1/2-port PCI-X RAID controller card to one of these? I don't intend to use the RAID function, but I'd be using it for the boot drive(s) so would need it to be recognised as an AHCI device at POST. Any pointers?![]()
Bios was flashed for the AHCI mod and I'm using the onboard sata port for the ODD for another 500GB for the OS and VM's. Lets me with the 4 ports of the motherboard free. May later take a multilane feed out to another external enclosure.
Yep, that's what I'm wondering.I think he was wondering if you were using a sata to esata cable for the external port. Although that is a serious amount of drives there![]()
