Good to know.
The 90 day warranty still concerns me![]()
http://www.overclockers.co.uk/productlist.php?groupid=595Where are you looking?![]()
I'll give you a counter example:
This has 10+ in stock, now it's possible that some are in damaged boxing, brown boxed, missing adapters, driver discs, etc.
Say it normally came with a DVI->Dsub & a DVI->HDMI adapter, and it was listed as brown boxed, but this particular one only had a DVI->Dsub; it'd have to be listed like that. Otherwise you might buy it thinking it had the DVI->HDMI when it doesn't. They probably wouldn't list it as not having either, because imagine buying it, then buying an adapter separate, receiving it and it having the adapter you just paid a fiver for.
It's a good idea, but I'm not sure how easy it would be to implement. I suppose one way could be to use the same drop down selectors in that the systems section use.
Seems like 5UB already got this covered though
Right so the feedback I have had is:
Make sure the prices are good and not above the new retail prices.
Mention the warranty on all product descriptions.
Mention some information to the product page as to why the product is B-Grade.
Possibly add sometime some photos of the products so you can see what you are getting.
Any more, just let me know.![]()
Well done.
How frequently does this page get updated? Just wondering?
this page? Don't think it will get updated much anymore. It will probably be dead in a few days.
Keep your eye on the B-Grade stock throughout the day, shall be working on most of it today.![]()
Crickey, this is cheap:-
http://www.overclockers.co.uk/showproduct.php?prodid=BG-180-MS&groupid=595&catid=683&subcat=
If i needed a new card i think i'd get that
If OcUK B-grade stuff was cheaper, it might be worth getting.
However whenever I've looked, the B-grade stuff was almost as expensive as the normal stuff, so it's not worth it.
