It does say salt water:-
Just grow it in large sea pens.
35,450km2 is only about 15% of the size of Arizona.although it would only take (from some crude maths) 8.76 million acres (35,450 km² )of land to produce enough fuel to meet the Us daily usage of petrol/diesel.
And that's not including the ethanol they produce at the same time.
That's actually a pretty reasonable amount of land.
You mean like the logistical nightmares of producing oil and gas from the huge swathes of empty areas that we do already?And if you don't see the logistical nightmare in that then.....
You could still grow it in pipes or bags in the sea.
What do you achieve. Unlimited supply of sea water. Huge growing area in some of the best sun light parts of the world.
Who said pipes or bags would be under the sea water
I don't see why it wouldn't be allowed.
But again it depends on a lot we just haven't been told.
There's no reason to believe that the sea water needs to be treated.And you still have to treat the sea water anyway
Why would it be delicate, again another found less assumption.
Ah sorry I thought you meant it had to be de-salinated, that sort of stuff you refer to isn't a big issue.The natural life in the sea water would be an issue, natural algae etc would clog the tubes/grow on the surface and block the light.
The other bacteria would kill the modified bacteria, the sea water may contain phage's that would wipe out all of the e.coli.
Why would that be hard to build at sea? And why would a storm break it?
Have you got any idea of structures in sea, especially as they don't even have to be anchored like oil rigs. Glass is extremely strong.
you think you can build a 20 square kilometre structure in the sea easily?
When it's going to have to meet up to regulations regarding oil spills etc.
