My F3 drops to 1-2mb occasionaly although Performance hasn't been affected. Maybe its just HDTune playing tricks.
Well if your problem is anything like mine, I recommend trying another SATA cable!
I just tried my older seagate with the cable which was causing problems with the samsung and im getting 217mb burst rate!!?? Which is higher than the samsung F3!! What on earth!?
Are you using AHCI Mode as well? I only really noticed it since switching to AHCI Mode when i reinstalled Windows.
Wow now theres something, I've not got AHCI mode enabled in my bios.. I tried enabling it but I couldnt get into Windows... So if I were to reformat the drive while in AHCI mode would I see any performance increase?!
Well you're meant to use this on all ssds I've heard so give it a go. Get another 2gb of memory too though it's super cheap these days.
Do you have loads of files or have the drive partitioned? I came to the conclusion that that's why mines drops suddenly. Ordered a F4 for Storage so i will try Benchmarking the F3 with Only my Windows Installation on it, Tommorow.Hey Duderooni.
Hard drives are made using CD looking disks. The maximum in terms of storage these (Platters) tend to get is around 350-400mb.
As a result, you typically see 500-750gb drives with two or three of these Platters, and 1TB drives with three or four or five, and more as the the size increases.
Due to a larger amount of moving mechanical parts, and the fact data may be spread across several platters, this will impact speed. Typically you'll find 500-750gb drives slightly faster than larger drives as a result.
Hope that helps mate![]()
You're a bit behind the times.
Platter size is up to 1TB now.
And the most platters you can fit in a 3.5" HDD is 4.
There aren't any drives out with 1TB platters though, also some disks contain5 platters.
