Hard drive space being used up but no sign of files?
Caporegime
3 Jan 2006
Chadderton, Oldham
Hi.
On another HDD partition all the files come up as using 156gb, but only 27.6gb is free when the partition size is 298gb?
Any ideas?
I would windirstat it first to see if anything obvious comes up, if the space is just missing then scandisk it.
windirstat? Browse the directory? I have
Scandisk? As in cmd do chkdsk or use a specific programme?
Was just about to say I have just "fixed someone's external who had the same problem.....turns out there was nothing to fix they had just hidden the files!
folder settings, turn on view hidden files :D
