http://forums.guru3d.com/showthread.php?t=345525
> Download < | > Mirror <
Mobility FIX (Use this only if you can't install the driver with the above package, extract this in the directory of the driver and install everything via setup.exe)
So... The driver date is a little bit older: May 12 but the build is 8.86, also Direct3D, 2D, and OpenGL are newer, right now I don't have time to test to see if it has the fixes contained in the 11.5b hotfix, but I can tell you one thing: MOUSE LAG IS FIXED that's the first driver for me that fix this damn bug, so maybe it is 11.6 or one of its builds.
Mobility support is included like the one from 11.5b, some card may fail at install, i will provide later a fix for it. (like in the 11.5b)
I need to go to bed now 05:00 AM here ****! Ehehe what you do when a new build comes to you.![]()
See you guys tomorrow!
