Why don't you try asking OcUK
You probably should have asked the question of OcUK before ordering otherwise how do you know the board they use has the features you want.
Unfortunately unless someone has bought one then we can't know.
Why don't you try asking OcUK before they send out your order.
Which is why I asked before the order was completed![]()
Its a Gigabyte Z68X-UD3P which is fine. Supports crossfire if i wanted to go down that route, only 8x though.
