** Raid Packs are BACK!! SSDs now included! ** Order Now!
20 Jul 2009
The bleak North East arm pit of Britain
Hello!
Raid Packs are back at OcUK after the success of the RE2 drives before Christmas!
To start the ball rolling we have the Agility 3 60GB in RAID pack! Saving a good £15 ex vat :)
More lines will be added over the next few days so keep posted :D
RAID PACK - 2 x OCZ Agility 3 60GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-60G) @ £185.98 inc VAT
As the third generation of the Agility Series, OCZ Agility 3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Agility 3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Agility 3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.
Using the latest break through controller and flash technology, Agility 3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.
- Capacity: 60GB
- Controller: SandForce SF-2281
- Maximum Read: 525MB/sec
- Maximum Write: 475MB/sec
- Max I/O Per Second (IOPS): 50,000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Only £185.98 inc VAT.
ORDER NOW
Great idea! :)
Also it could be good for two friends who wants SSD's to share and buy this pack. Nice price!
Although warranty could be an issue as it is not transferable.
More RAID packs please this is a great idea.
Can we see some packs based on multiples of 3/4 of 1TB, 1.5TB, 2TB and 3TB spinneys as well? I build a lot of media servers and discounts based on multiple drives would be great. Coupled with the free delivery this would be unbeatable, as currently I buy drives elsewhere.
Great idea! :)
Not really, if my mates one died I would return it under my name cause I bought it. Problem solved :rolleyes:
That is true, if it is a good friend then there shouldn't be any problems.
would you be able to post the theoretical raid 0 performance underneath the single drive specs as well? (Obviously about double, but for those who like to see big numbers or can't be bothered working it out) :P
such as:
Single Drive Specs
- Capacity: 60GB
- Warranty: 3 Years
Theoretical RAID 0 Specs
- Capacity:120 GB
- Maximum Read: 1.05GB/sec
- Maximum Write: 950MB/sec
- Max I/O Per Second (IOPS): 100,000 IOPS (4KB File) <---(would this be correct?)
- Warranty: 3 Years
