You probably need to read about Transitive relation.LOL! you have no concept of comparison at all, how can you compared a 1.5gb to 3gb jump to 1.2gb to 1.5gb jump?
OF COURSE extra 1.5gb (100% increase) is going to give you a better performance - it's doubled ffs, but show me where it says extra 300mb (25% increase) will?
Delete your post, please don't confuse OP with that irrelevant comparison.
Time to go back to school 'drifting'?
edit: just noticed maybe he is spamming to get to 250 posts for free shipping![]()
So his suggestion is get a 580GTX with 3GB, ofcourse if you can get a 590GTX with 1,000GB it will last you a life time and you will be able to give it to your next generation since VRAM is the only thing that matters, I don't even know why GPU cards are not called VRAM sticks!![]()
 All for a mere £10 more than the MSI 570.
So your comparing a 570 for £250 and a 480 for £225.
570 has less memory but is ~ same speed at stock.
480 is louder, uses more power, but cheaper with more memory, and overclocks better.
My solution is to spend £5 more add a "Zalman VF3000-F Graphics Card Cooler" to the 480 and remove the heat and noise issues. Like i did!
Asus 480 £225 + Zalman £35 = £260. Then clock the hell out of it!All for a mere £10 more than the MSI 570.
Overclocked the 480 will eat the 570 for breakfast. Sorted.![]()
first of all transitive relation has nothing to do with what we are talking about... there is no need to be pretentious! Show me your application of transitive relation in this situation.
The point still remains 570 out performs 480 even at 2560x1440.
the picture you posted in #13 is irrlevent, once again, it's comparing a 480 to 470, where the variable is NOT JUST VRAM - they the same generation ffs. 480 to 470 is more like 580 to 570, NOT 480 to 570...
Why are you so fixated on VRAM!!!??? like you said it's diminishing returns, why not waste your time on comparing something that will give you more than 0.000001fps per GB.
1.5GB < vram wall
1.2GB < 1.5GB
Therefore 1.2GB < vram wall.
Same generation tells better on the vram limitation. If you think GF110 is a better architecture then could you list it?
Yeah the 570 can't be overclocked, OH WAIT!... Seriously good comparisons to be had here thats like comparing a stock cpu to a oc'ed cpu GTFO.
I have to say - as much as I'vehad problems with my GB SOC 480 - it is quite cool relatively - cooler than my 570 was at much higher volts
I'm at 1.10V and in gamesit doesn't get above 81C![]()
