losing lots of my ZvP to Mass void ray with 3 air attack : /
started baneling busting natural to slow them down but still comes down if i can get up my 3rd to get enough gas for hydra or corruptor or mix of the 2.
Im still in bronze but been playing vs some gold/silver players on ladder which might indicate i'll get promoted soon.
After initial 5 placement games i was palced in gold aswell, then long losing streak hapenned and i was bottom of my bronze league, now ranked 8ish
Playing mix of Spanishwa / mass crackling, zergling do pretty good vs protoss until they get colossus// loads of forcefields
I'll admit i have been erm.. 6 pooling few games cheesy hehe, normally in the game after i get cannon rushed or something
Been watching some live feeds from pro's.. low graphics quality settings look so erm.. weird![]()
Another Zerg player
Best thing to do is keep your scouting drone alive in his base for as long as you possibly can.. just keep him moving if he's been chased or keep him hidden. Failing that, its always worth suiciding an overlord into his base (where you think he might hide his tech buildings).. the 100 mineral/larva loss is worth knowing what he's doing.
My general build is to Fast Expand, regardless! These days both Protoss & Terran have the ability to do the same, and if you don't do it, either at around 13-14 pop, or at 20-21 pop then you'll be too far behind. ZvZ s a different ball game though.
So going with the fact that you have fast expanded, I normally just sit in my base after scouting VR's - For defense i tend to just mass up queens (4-5). They are shockingly powerful and will often just chase down VR's... not to mention you can use them to heal each other pread creep, along with defending ground at the same time. If they have gone for a lot of VR's then you will need to transition into Hydras. If they have gone for 1-2, you can get away with getting another expansion off, or by droning up REAL hard
Also.. everybody likes to 6 pool from time to time
