** Gigabyte 990X AMD AM3+ Boards ** NOW IN STOCK!!
20 Jul 2009
The bleak North East arm pit of Britain
Gigabyte have landed with AMDs flagship 990X chipset series of boards!
All lines are in stock and ready to ship so be one of the first to harness the new power and potential that these feature rich boards have to offer! :D
Gigabyte 990FXA-UD7 AMD 990FX (Socket AM3+) DDR3 PCI-Express ATX Motherboard @ £205.99 inc VAT
The 990FXA-UD7 motherboard is designed to offer a stable, high-speed platform for delivering amazingly fast data transfer via the GIGABYTE 333 onboard acceleration technologies. Featuring the USB3.0 controller, AMD 900 series motherboards allow users to take advantage of super fast USB transfer rates of up to 5Gbps, delivering 10x faster data transfer compared to USB 2.0. Utilizing the industry's first Serial ATA Revision 3.0 solution via AMD SB950 chipset, GIGABYTE AMD 900 series motherboards offer native 6 ports of next generation high speed data storage devices support with data transfer speeds of up to 6 Gbps with RAID 0, 1, 5, 10. The AMD 900 series motherboards introduce a unique hardware design with lower resistance fuses for ensuring lower voltage drops and providing more stable and plentiful power delivery. All USB ports also benefit from a 3x power boost for better power delivery to power hungry USB devices.
- Back panel connectors: 1x PS/2 keyboard/mouse port, 1x optical S/PDIF Out connector, 1x coaxial S/PDIF Out connector, 1x IEEE 1394a port, 7x USB 2.0/1.1 ports, 2x USB 3.0/2.0 ports, 1x eSATA/USB Combo connector, 1x eSATA 6Gb/s connector, 1x RJ-45 port, 6x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone)
- Cpu: AM3+ Socket: Support for AMD AM3+ FX processors, Support for AMD AM3 Phenom™ II processors / AMD Athlon™ II processors
- Expansion slots: 2x PCI Express x16 slots, running at x16 (PCIEX16_1, PCIEX16_2), 2x PCI Express x16 slots, running at x8 (PCIEX8_1, PCIEX8_2), 2x PCI Express x16 slots, running at x4 (PCIEX4_1, PCIEX4_2)(All PCI Express slots conform to the PCI Express 2.0 standard.), 1x PCI slot
- Ieee 1394: Up to 2 IEEE 1394a ports (1 port on the back panel, 1 port available through the internal IEEE 1394a header)
- Internal i/o connectors: 1x 24-pin ATX main power connector, 1x 8-pin ATX 12V power connector, 1x PCIe power connector, 8x SATA 6Gb/s connectors, 1x CPU fan header, 2x system fan headers, 1x power fan header, 1x front panel header, 1x front panel audio header, 1x S/PDIF Out header, 3x USB 2.0/1.1 headers, 1x USB 3.0/2.0 header, 1x IEEE 1394a header, 1x Trusted Platform Module (TPM) header, 1x clearing CMOS jumper, 1x clearing CMOS button, 1x power button, 1x reset button
- Lan: 1x Realtek RTL8111E chip (10/100/1000 Mbit)
- Memory: 4x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory, Dual channel memory architecture, Support for DDR3 2000(O.C.)/1866/1600/1333/1066 MHz memory modules
- Storage interface: South Bridge: 6x SATA 6Gb/s connectors (SATA3_0~SATA3_5) supporting up to 6 SATA 6Gb/s devices, Support for SATA RAID 0, RAID 1, RAID5, RAID 10 and JBOD 2x Marvell 88SE9172 chips: 2x SATA 6Gb/s connectors (GSATA3_6, GSATA3_7) supporting up to 2 SATA 6Gb/s devices, 2x eSATA 6Gb/s connectors (including 1 eSATA/USB Combo connector) on the back panel supporting up to 2 SATA 6Gb/s devices, Support for RAID 0 and RAID 1
Only £205.99 inc VAT.
ORDER NOW
Gigabyte 990FXA-UD5 AMD 990FX (Socket AM3+) DDR3 PCI-Express ATX Motherboard @ £159.98 inc VAT
The 990FXA-UD5 motherboard is designed to offer a stable, high-speed platform for delivering amazingly fast data transfer via the GIGABYTE 333 onboard acceleration technologies. Featuring the USB3.0 controller, AMD 900 series motherboards allow users to take advantage of super fast USB transfer rates of up to 5Gbps, delivering 10x faster data transfer compared to USB 2.0. Utilizing the industry's first Serial ATA Revision 3.0 solution via AMD SB950 chipset, GIGABYTE AMD 900 series motherboards offer native 6 ports of next generation high speed data storage devices support with data transfer speeds of up to 6 Gbps with RAID 0, 1, 5, 10. The AMD 900 series motherboards introduce a unique hardware design with lower resistance fuses for ensuring lower voltage drops and providing more stable and plentiful power delivery. All USB ports also benefit from a 3x power boost for better power delivery to power hungry USB devices.
- Storage interface: South Bridge: 6x SATA 6Gb/s connectors (SATA3_0~SATA3_5) supporting up to 6 SATA 6Gb/s devices, Support for SATA RAID 0, RAID 1, RAID5, RAID 10 and JBOD, 2x Marvell 88SE9172 chips: 2x SATA 6Gb/s connectors (GSATA3_6, GSATA3_7) supporting up to 2 SATA 6Gb/s devices, 2x eSATA 6Gb/s connectors on the back panel supporting up to 2 SATA 6Gb/s devices, Support for RAID 0 and RAID 1
- Internal i/o connectors: 1x 24-pin ATX main power connector, 1x 8-pin ATX 12V power connector, 8x SATA 6Gb/s connectors, 1x CPU fan header, 2x system fan headers, 1x power fan header, 1x front panel header, 1x front panel audio header, 1x S/PDIF Out header, 3x USB 2.0/1.1 headers, 1x USB 3.0/2.0 header, 1x IEEE 1394a header, 1x serial port header, 1x clearing CMOS jumper, 1x Trusted Platform Module (TPM) header
- Back panel connectors: 1x PS/2 keyboard/mouse port, 1x optical S/PDIF Out connector, 1x IEEE 1394 port, 8x USB 2.0/1.1 ports, 2x USB 3.0/2.0 ports, 2x eSATA 6Gb/s connector, 1x RJ-45 port, 6x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone)
- Expansion slots: 2x PCI Express x16 slots, running at x16 (PCIEX16_1, PCIEX16_2), 1x PCI Express x16 slots, running at x8 (PCIEX8), 2x PCI Express x16 slots, running at x4 (PCIEX4_1, PCIEX4_2), 1x PCI Express x1 slot (All PCI Express slots conform to the PCI Express 2.0 standard.), 1x PCI slot
Only £159.98 inc VAT.
ORDER NOW
Gigabyte 990XA-UD3 AMD 990X (Socket AM3+) DDR3 PCI-Express ATX Motherboard @ £93.98 inc VAT
The 990XA-UD3 motherboard is designed to offer a stable, high-speed platform for delivering amazingly fast data transfer via the GIGABYTE 333 onboard acceleration technologies. Featuring the USB3.0 controller, AMD 900 series motherboards allow users to take advantage of super fast USB transfer rates of up to 5Gbps, delivering 10x faster data transfer compared to USB 2.0. Utilizing the industry's first Serial ATA Revision 3.0 solution via AMD SB950 chipset, GIGABYTE AMD 900 series motherboards offer native 6 ports of next generation high speed data storage devices support with data transfer speeds of up to 6 Gbps with RAID 0, 1, 5, 10. The AMD 900 series motherboards introduce a unique hardware design with lower resistance fuses for ensuring lower voltage drops and providing more stable and plentiful power delivery. All USB ports also benefit from a 3x power boost for better power delivery to power hungry USB devices.
- Back panel connectors: 1x PS/2 keyboard/mouse port, 1x optical S/PDIF Out connector, 1x IEEE 1394 port, 8x USB 2.0/1.1 ports, 2x USB 3.0/2.0 ports, 1x RJ-45 port, 6x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone)
- Expansion slots: 1x PCI Express x16 slot, running at x16 (PCIEX16), 1x PCI Express x16 slot, running at x8 (PCIEX8), 1x PCI Express x16 slot, running at x4 (PCIEX4), 2x PCI Express x1 slots (All PCI Express slots conform to the PCI Express 2.0 standard.), 2x PCI slots
- Internal i/o connectors: 1x 24-pin ATX main power connector, 1x 8-pin ATX 12V power connector, 6x SATA 6Gb/s connectors, 1x CPU fan header, 2x system fan headers, 1x power fan header, 1x front panel header, 1x front panel audio header, 1x S/PDIF Out header, 3x USB 2.0/1.1 headers, 1x USB 3.0/2.0 header, 1x IEEE 1394a header, 1x Trusted Platform Module (TPM) header, 1x serial port header, 1x clearing CMOS jumper
- Storage interface: South Bridge: 6x SATA 6Gb/s connectors supporting up to 6 SATA 6Gb/s devices, Support for RAID 0, RAID 1, RAID 5, RAID 10 and JBOD, 2x Marvell 88SE9172 chips: 2x eSATA 6Gb/s connectors on the back panel supporting up to 2 SATA 6Gb/s devices, Support for RAID 0 and RAID 1
Only £93.98 inc VAT.
ORDER NOW
You just spent £207 without knowing anything about AM3+? Without reading any reviews? Without knowing how AM3+ performs relative to SB or even your Core i7?
Wow, I envy you!
Been waiting and waiting mate. It may not turn out to be a great move.. But hey ho, life is full of experiences ;) This was the board I was after though... CHV has had superb reviews so cannot imagine this is going to be a fail.
I was waiting and waiting for Bulldozer, gave in and bought Sandybridge, perhaps you should have done that, as we all know that a even a mildly overclocked 3.8-4GHZ 2500K will waste a [email protected] :p mines currently at 4.8GHZ and thats without trying:D
I have to say, £93.98 for an SLI compatible motherboard that isn't MATX or a crap chipset is a great deal, and should show Intel how it's done, especially given the 6x native SATA 6 ports, and USB3.0 rear ports and header as standard...
So are we in agreement that buying one of these boards and a cheap phenom II (say a 955) is both wise and future proof?
No.
Wait until figures for AM3+ are released.
These prices are about in-line with SB mobos.
If AM3+ isn't as fast as/faster/much cheaper than SB then it would be a stupid move to make.
