what cpu coolers would you suggest for ease of installation/performance and ram accessability?
well, any cpu cooler is easy to install. they wouldnt sell otherwise.
specifically for ram accessability, you would have to go for a simple tower cooler such as the megahalems or venX.
Was a impulse buy from ocuk when it was £35.99, thinking of getting the H80 or should I just stay away from these closed water system?
stay away tbh. a h80 will perform only a little better than this h50.
i would look at a nice high end air cooler, something like a bequiet darkrock pro or noctua nhd14
from my testing, the Prolimatech geneisis is amazing. i would have that if i used air cooling. you already have the fans so the cooler would be a lot cheaper than the H80.
So why do OCUK overclocked systems use them?
The "Titan Spinosaur" for example.
because they are excellent for shipping complete systems in transit and avoid courier damage.
can't knock them for system integration use at all, they are superb in that aspect.
they do the job, but this is an enthusiast forum.
people who buy complete systems tend not to be hardware enthusiasts. or want a system that 'just works'
for the end user who builds/configures/tweaks their own system its best to get the bang for buck option that allows maximum headroom and potential.
thats just how i see it anyway, im sure you would agree.
