- 20 May 2011
I have a HAF932 pc case with all its standard big fans, I also have mesh filters on the two intake fan areas which has increased the temp on my cpu by about 5 degrees and on the North bridge with about 10 degrees.
everything is clean inside, i cleaned it all out.
I have two hard drives, one at the top of the hard drive rack and one at the bottom so that in theory it lets the front intake fan blow in air with not much obstuction.
I have two dvd drives above them in the area where you put dvd drives.
I have an msi x58 platinum motherboard with 6 GB corsair ram on it, I'm using onboard sound.
I also have an ATi?amd HD 6990 graphics card in the top pci-e graphics card slot.
I think thats about all I have apart from a 1000watt coolermaster psu which is in the very bottom of the case.
Problem I have noticed though is that since adding the two intake fan mesh filters to the side fan and the front fan is that my temps are up on the cpu by about 5 degrees and on the northbridge by about 10 degrees.
Can someone please give any advice apart from removing the mesh filters as to how I could get the temps down a bit on the psu and the north bridge ?
On idle the cpu is at about 28-30c and the northbridge is about 70c, before I added the mesh filters the cpu was about 25 and the northbridge was about 60c.
I have looked to see if i can fit another fan, but i cant see anywhere i could, does anyone have any ideas at all on this please ?
p.s
The cpu is an i7 920 clocked to approx 3800 to 4000 with turbo boost on, i have an ocz gladiator max cooler on the chip.
Any ideas would be very much appreciated please, thanks
p.s
No mate different stuff inside, so obv somethings making a difference there. But you would think air flow would be getting restricted like yours, am sat here taking them on and off now and do notice a slight difference. Trying to figure out if I've got anything different fan wise to you but mine are all stock facing like yours I assume. Bit of a bugger as I find them pretty handy but 10 degrees is a bit of a jump.
