Just had a pop at the Fiat Race..
Needed some tweaking/tuning
Used glass lightening to get to 1000Kg, and got the power to 65BHP using whatever air/exhaust mod gave us this.
Added all the clutch/flywheel tat that doesn't affect power/weight..
Then fully adjustable gearbox and suspension
Final drive increased to give 93 MPH top speed
Suspension tweaked
Front Toe -0.15
Rear Toe -0.00
Front/Rear Camber (-)0.3
Ride height Lowered to just about 20% of the slider
Front Arb 1, Rear 4 (gives nice turn in)
I think that was about it, it's mainly about the lines through the corners.. you need to aim for about 2:03.500's or less, my last lap was 2:03.1xx and I won by 5 seconds or so..
Flat out through the first chicanes, sweep wide into the tunnel, drop to fourth, and hold about 62 mid corner dropping to 57-58MPH by the time you reach the top, brake early and again a wide line into the tight right, should be hitting 53MPH mid corner, 3rd or 4th is OK, then flat out round the next corner, into the tunnel, feather the throttle to hold 64MPH as you turn in early..
The thing for the corners is to hang out really wide, brake early and really nail the apex..
Thanks for that, will have a check of my settings tomorrow when I get a chance. Would be nice to win this one
