Harvey i would probably stick with a domi than a tengu for missions, unless you are planning on running null sec missions for a pirate faction using an unprobable setup. Otherwise the domi will do faster dps and generate better isk per hour. And if you do have a "welp" moment a domi is very cheap to replace.
If you want easy pvp look around for a faction warfare corp rather than a null sec corp. These will generally have less stringent requirements as far as skill points are concerned. Get yourself a decent pile of kills under your belt and you will be a more interesting prospect to the null sec pvp corps.
