*chicken strips* lol
I would defo replace that, wouldn't displace standing water all that good either.
Minimum depth for motorcycle tread is 1mm , that look less than that (I'd go with 0mm) so unless you want to get a tug and a fine from the boys in blue I'd get a new one pronto!
RD
I'm with Rabid, 2300miles and i'm about half a mil off the indicator...
Think i may be a little harsh on the throttle
Most tyres will go "off" near or around the end of their serviceable life. At 6k and going by your picture I'd say that one has a good chance of being there at the "off" stage where it will begin to feel just not right and a wee bit marbley, tracking excessively over white lines etc. In which case, irrespective of the amount of tread left, I'd be replacing it.
Michelin Pilot Power 2CT's are the win, btw.![]()
what make are your tyres ??
+1 on the Pilot power 2CTs
not the cheapest of tires, but great in the wet as well as the dry.
Metzeler M5's
How would you rate them?
I myself have Michelin Pilot power 2CT's and can honestly say there probably the best I've tried, and I've tried most makes over the last 14 years.
growse
the Pilot Power 2 CT's are hard wearing in the middle and softer/sticky on the outside to aid cornering so no matter if you have 80 or 180 bhp are a very good choice fro the commute as well as a sunday blast and trackdays.
RD
growse
RD
