I found the voltage increase from 4.7 to 4.8 was massive.
is anyone else seeing quite a big voltage increase needed between 4.2 and 4.4?
1.232 for 4.2 looks like it will be stable for me but 1.31 for 4.4 failed prime
Mine doesn't need a lot up to 4.7 but 4.8 looks like it's going to require a hefty jump to be 8 hours stable. I'm probably going to need about as much of a voltage increase to get from 4.7 to 4.8 as I did from 4.5 to 4.7, on current evidence.
Do you have PLL Voltage enabled 24/7 for your 4.8 overclock?
what would you consider not a lot? whats your volts for 4.7?
Yeh I think 1.4 is about normal for 4.8 on the 2600k. I've yet to see any screenshots with significantly lower vcores that are Prime Blend stable. I think the 2500ks require less on average.
If the 2600K is switched Hyper Threading off (disabled) then vcore will be less of course.
But that makes the 2600k pointless lol.
not really, i had both option choice either HT enabled for winter and HT disabled in hot heatwave summer. Useful.
