GPU Waterblock recommendations
15 Dec 2002
In a cowfield, London, UK
Herro! Been building This machine for the past week or so, as my older E6600 was getting a bit useless for gaming.
However at present I'm still using my old ATI 4870HD card. I'll be purchasing a new card soon and will obviously add that to the WC loop. Can anyone recommend blocks for say an ATI 6970? By the time I get the GPU, they'll have dropped in price methinks.
I still have a spare 120.2 Rad here to supplement my triple one if needed.
Whatever graphics card you get make sure it's a reference design.
Reference design cards are most likely to have a full cover block available.
Cheers for the help guys. Looks like I'll opt for an EK block then when I get me next GPU :) Those pics above look tasty!
The Koolance blocks look awesome too :)
and the ek blocks with white delerin :)
I tried to take a pic direct from the koolance website of the gtx 480 block but I don't think I can link as they sell waterblock too, and the delrin block is the ek 580 one
take screenshot and use imageshack uploader?
Snipping ool is good if ur on win 7
OMNOMONOM @ Koolance one :D
I'll most likely run a separate loop for the GPU alone, as I have a spare RX240 rad and I may go SLI in future just for the sake of it. I aim to get a new GPU just before BF3 ships anyway.
keep it in one loop. Makes no difference to temps
just get the cheapest full cover block you can find, you wont see it anyway as its on the underside of the card, being an old card you should be able to find one very cheap. I got water blocks for my 480's for £28 each
after a quick google search found a place selling a full cover block for ur card for £22
