can you explain (cause I'm stOOPid) why my 570w trust psu is rubbish but the lower wattage 500w 550w you reccomend would be find to run a i5 2400 system?
thanks for the advice pastymuncher. would I be better with a higher wattage I was thinking of 600+ any reccomendations in that range?
 XFX 550W is a good PSU for a budget gaming rig as well. Corsair GS ain't too bad either.You are missing the point...who cares if Phenom II X4 965BE beat i7 870 by a little at Batman when comparing at stock speed? What people cares to know is the Phenom II X 965BE can only overclock by around 12-16%, when the i7 870 can overclock by 33-40%. Which is a better chip? it is obvious.yeah. for instance, a 965 is quicker than an i7 870 in batman AA (still an old game, mind), but because the i3 2100 was never benched in that game, it isnt included in the i3 vs 965 results.
With a good quality 520W PSU like the Antec or the 550W XFX you can happily run an overclocked i5 2500K system with pretty much any single-GPU graphics card on the market.
So unless you want to be ready for a second graphics card or go for one of the really high end graphics card (eg GTX 580) then an even higher capacity, more expensive PSU isn't strictly necessary - especially if you are compromising on other components to afford it.
However, if you do want to for a good quality 600W+ PSU, then the best options are the 620W Antec High Current Gamer, XFX Core 650W or the Corsair TX 650W v2.
Yea, it's a pretty decent unit - but I would still go with the seasonic designed, higher effiency XFX 550W for £4 more. With your setup you certainly won't be needing the extra 50W capacity the OCZ can offer.
Well, I agree that Anandtech bench is far from perfect, but there are a few places which clearly show the i3 2100 alone has made Phenom II X4 or X6 a bit...well, not worth getting if building a new system for gaming now.oh no, i know that very well. However that's another discussion, i was mearly commenting on a misleading post. you've taken that out of context however - i added that link to show where the stock performance was in that particular game - well above where the i3 would be had it have been tested.
Anand's gaming benchmarks are all out of date anyway, so as far as I'm concerned none of them are relevant any more.
Concentrate on the gaming results![]()
Just look at the following:
http://techreport.com/articles.x/20873/2
Here's what I think:
The i3 2100 is faster than ANY Phenom II in BFBC2, even the Phenom II X4 980 which is clocked at 3.7GHz. And then look at CPU intensive game that that are not optimised to use 4 cores fully such as Civilization V...the i3 2100 has a clear lead over the Phenom II CPUs. In F1 2010 the i3 2100 has a clear lead again. In Metro2033, the Phenom II does slightly better than the i3 2100. Now the important part- the i3 2100 can deliver better/compariable performance to a Phenom II X4 at 3.7GHz, with only half the power consumption (i3 2100 TDP 65W vs Phenom II X4 980 TDP 140W), so why give extra money to the energy company? Plus the i3 2100 runs so much cooler and is perfectly fine to use just a stock cooler, whereas the Phenom II X4 at 3.7GHz would pretty much require a 3rd party cooler with cost another £25-£35.
