*** Can you Post your Crucial M4 SSD benchmarks in here ***
I do lots of number crunching for my PhD but my programs never need more than 4 MB of RAM so I'm guessing it's probably something involving very large databases.
oil and gas.
the raid seems to be running quite a bit slower now though, only around the 500mb mark, wondering if there is an issue with TRIM on raid disks. Any tips?
Before when I had the M4 plugged into the Marvell controller, white port nearest the OC Genie button, wondered why the Intel driver/AHCI wasn't showing!
After I had swapped the cable to the top, with the board in the case (white) port, much better!
Keep in mind that the majority of performance that makes an SSD feel awesome over a HDD is the lower end performance, NOT the silly higher sequential, and because that low end performance is miles and miles below max sata 2 performance. Look at Rajravat's benchmarks, sure sequential is faster but its only what, 5 times faster, look at the monumental performance increase in 4kb random read/writes roughly 40 times faster in each case there, and the queue depth makes a huge difference in SSD's, higher queue depth usage for 4kb random is well, over 200 times faster.
Sequential wasn't even really a huge bottleneck on HDD's, its nice the few times you move massive files, but the bottleneck that made systems stutter, and take a while to access files and start loading, thats all the random performance, sata 1 allows a SSD to feel like a monumental improvement to HDD's.
Thing about Crucial drives though is they really are crippled in the 60gb size. I went with a C300 but went up to the 128gb model. Bit of a shame the denser smaller memory chips are both killing write performance, and giving lower life expectancy. Vertex 3 240gb is awesome, the 120gb and 60gb are FAR less impressive, good but far less good.
I'm gonna be totally honest with you here, I havn't got a clue about anything you wrote :( I don't know much about SSDs only that they are faster than mechanical one and are silent (althugh Im sure mine make a feint ticking noise at times). But as long as my benchamrks loog good for Sata 2 and I've done all I can to prolong the life of my SSD I'm happy :)
