Ice Cream maker - who has one?
Caporegime
20 Oct 2002
Wish i was in a Ramen Shop Counter
Simply put, I want to get an ice cream machine. There is always ice cream in my freezer, whether it is vienetta, cornetto, Ben & Jerry's Haagen daz etc. So I thought why not try it myself. All it seems it takes is getting the base right, and then experiment to the max for some funky results.
What particularly interest me is making my own frozen yogurt...can't for the life of me find anything other than Cherry Garcia! and at £4 a tub it isn't cheap.
So after doing some research, it seems the machine with a built in compressor are the best bet. Mainly for 2 reasons.
1 - No need to chill the bowl a day or over night before hand. So if i want to make ice cream on impulse, i can.
2 - I saw some youtube vide, the "bowl" for the machine i wanted to get are WAY huge, it doesn't look like it will fit in my freezer, not without taking some food out.
With the 2 above, the lack of planning (i am too impulsive when it comes to food) and can't keep the bowl in the freezer all the time it means i will seldom use it.
Which leaves the option of getting one of those with a built in compressor which after some research....this one.
Gaggia Ice cream maker
It is a little pricey (though it is the same price as my Gaggia espresso machine), but for a life time of fresh ice cream?
Anyone got an ice cream machine? whether a bowl one or a compressor one? If you got a bowl one, did you wish you got one with a compressor or vice versa?
How often do you eat ice cream?! £200 seems a lot! :eek:
It's not £200 for a month, i am expecting this to last yearssssssssssssss.
Reading reviews, some lady had the previous model for 10 years and still working, that's £20 a year! I've had my Gaggia Espresso machine 3.5 years now and that was £200 too.
Ah okay fair enough. I say go for it if they last that long, it's stylish as well, as style goes for ice cream makers. :D May as well pay for a quality product instead of an Argos value thing for a tenner which breaks after the 2nd attempt of using it!
How do you make ice cream in it any way, different flavours etc?
You make the base, which mostly a custard like liquid. You pour it in and press the button. If you put the custard straight into a freezer it'll be a block of hard solid ice. In the machine because it is turning all the time it stops that crystalisation, so you get a smooth product in the end. The different ice cream comes from different flavours you chuck in while it is turning. Ie smash up some Ferrero Roche for Ferrero Roche flavour. Mint & mango? Done (but you should caramelise the mango in a pan first to break it down a little and let it cool down beforehand) the possibilities are endless.
I have a Philips HR2304, just a cheapish one - but I don't always make ice cream, and the freezer disk is always in the freezer, so I can make ice cream when I decide. It makes 1L at a time, which is enough for me. Will buy another freezer disk though..to make more than one ice cream at a time. Doesn't take too long either. Would buy a more expensive one, but haven't got THAT into making ice cream yet..
I've got one - it's ace. Expensive, yes, but the results are far better than what you'd get out of a pre-freeze one.
Which one have you got? I've read some of them are rather loud in operation. The Gaggia one is over 12kg so it can't be moved around and it says it shouldn't either as if you do, you need to wait 24 hours for the coolant to settle first before using it.
I've got the cuisinart one - I don't think there's much to chose between them really as they work in v much the same way, I don'tknow if some have a bigger capacity though
They are loud yes, but it's only for ~35mins while it's churning. Not moving it could be a pain, I don't think it's an issue if you just move it horizontally, it's when you start turning it that it becomes a problem.
I work at a place that sells a £290~ Cuisinart and it does make fantastic ice cream, obviously at a price though! Makes 1.5litres a go :)
I had one, it was such a faff that it was used about twice and then lived at the bottom of the cupboard and never loved, or indeed missed, ever again.
