And before you all jump on this and say HAHAHA what do you need a 1000w psu for!?
I entered my current my current spec in to the eXtreme Power Supply Calculator:
Silverstone Fortress 2 case which has 3x180mm and 1x120mm fans
Phenom II X4 940
4x2GB DDR2
Noctua NH-D14 Dual Radiator CPU Cooler which has 1x140 and 1x120mm fans
2 4870x2 GPU's in Crossfire
5 SATA HDD's
1 DVD-RW/DVD+RW Drive
TV Tuner - Antenna
7 USB Devices
I wasn't sure what to put for the fans, I assume i should use 'High Performance' fans, but it doesn't have 180mm fans option.
If i choose 4x140 and 2x120mm
It gives me:
Minimum PSU Wattage: 898w
Recommended PSU Wattage: 948w
But if I overclock my CPU to 3.6Ghz
It gives me:
Minimum PSU Wattage: 980w
Recommended PSU Wattage: 1030w
Also, I was considering get the Corsair H80 if it ever come out!
Cheers
Phenom II X4 940
4x2GB DDR2
5 SATA HDD's
TV Tuner - Antenna
7 USB Devices
It gives me:
It gives me:
Cheers
