- 18 Oct 2005
- Leicester
just installed crysis 2 to give it a whirl my spec is in my sig below everything on max setting, now it starts you off in the sub you move when it gets destroyed and on fire and have to escape, i fall down the hole, then go to help the guy get the door open, the instant i press F on keybaord the pc turns off, then reboots again saying windows did not shut down correctly ect...
im thinking its to do with my power supply? not enough power? or could it be somthing else?
i disabled my overclock to try again and still the same, i can stay in the sub bit at the beggining for ages without it turning off, its just as soon as i go to open the hatch then bam! gone
ive ran heaven benchmark at top settings and that doesnt cause pc to turn off, also bioshock 2, duke nukem, fear 3 all fine just crysis 2 thats doing it?
