Turn Bottom mounted PSU upside down?
23 May 2011
My XFX 650w Black Edition PSU is about a month old but the fan is making a noticeable buzzing noise. I was thinking that maybe if I turn it upside down (So the fan if drawing air from inside the case) it may stop the fan buzzing. If it does happen to stop the buzzing do you reckon it'll affect the temps much, mostly the GPU which it'll be competiting against for air, if at all?
Thanks.
Should a PSU not suppose to be pulling ait OUT of the case?
I can not understand what you mean otherwise, DONT put the fan against any metal to restrict airflow if that your plan
At the minute it's pulling air like this:
Outside of case (Has ventilation)
If I do what I'm saying in my post it'll be doing this:
Inside of case
I might just be slow, is you SPU out side of your case? How is it mounted or do I have it all wrong?
Every PC I have built has had a specific spot for a PSU at the back and sucked out air from the case.
Sorry if I am rambling but perhaps i can not visualise your setup.
if turning it upside down eliminates that buzzing noise, then keep it like that, if it doesnt, i think its better to let it suck cold air from the bottom of the case and exhausting it at the back
:confused:
Where on earth did you get that from?
The PSU vents air out of the rear of the psu. Never the other way around (Unless someone has been hacking it)
I did not understand what the OP was on about so was a bit confused; as you will read the sentence again you will see I said it was never a good idea so he should not be doing so if that was his plan
I would agree with this, perhaps there is some dust some where, try giving the fan a slight tap perhaps, works for me.
