Btw.. engineers said I am 1km from the FTTC.
That's positive. I'm 750m and will be having the service installed next Wednesday.
What does the BT speedtest report?
Doesn't just go on the distance, it goes on line quality.
very true !
Also depends on age of exchange and equipment used in it.
Yeah the fibre kit is all new isn't it?
The only 'old' part of it would be the line between you and the cab surely?
who cares if thats new or not? as long as it can handle the speeds.
) so in that example you could say the fibre is "new"!
You don't have to wall mount the modem, but its advisable.
Take a look here for how i had it done...
http://forums.overclockers.co.uk/showpost.php?p=19158828&postcount=735
Anyone else notice they use a lot more bandwidth with Infinity, im at 68GB already this month.
What did you have before, I am on about 75GB already that's only from SabNZBd.
