(often erroneously called "SATA 3") is faster than SATA 3 Gbps (often erroneously called "SATA 2").
Crucial M4. £170 delivered.
SATA 6 Gbps (often erroneously called "SATA 3") is faster than SATA 3 Gbps (often erroneously called "SATA 2"). With the current generation of SSDs, they will easily saturate an older SATA 3 Gbps port so to get the best out of them, you need a SATA 6 Gbps port. Since you have this, your new SSD will operate at optimum speed. Make sure your set your SATA controller to AHCI in the BIOS too!
Because they're not correct. "SATA 2" and "SATA 3" don't exist.
Sure but the guidelines do not allow them. See this.Well... and I am trying not to get into an esoteric ontological debate here... Do the labels SATA 2 and SATA 3 not refer to the 2nd and 3rd revisions (or generations), respectively, of SATA interfaces?
I've seen a couple of benchmarks show the M4 being faster in 4k reads and writes, plus you don't have the incompressible/compressible data differences, plus you avoid any throttling of incompressible data, plus they seem more reliable right now. The M4 is also cheaper (OK, not on OcUK but I mean the cheapest price from a big retailer).But the Corsair Force Series 3 has faster reads, writes and more IOPS and is also cheaper... so why the M4? In fact its better on paper than the v3!
