- 16 Jun 2010
- Manchester
I am set on a mission to get custom watercooling cheaper than a pre-built watercooling unit.
Now i am after a decent setup with better results than the pre-built units and the expandability of being able to add further to the build when wanted/needed.
So far here is what i have sourced :
EK Supreme CPU Waterblock (Plexi)
Laing DDC Ultra with Plexi Top & Antivibration kit
2 x EK GTX480 Full cover blocks (Nickel/Plexi) Brand new
Tygon 3603 left over from previous attempts (just under 1m)
Danger Den Filport in anodised red
Silver Kill Coil
Now i am thinking all i need to finish up is a radiator or 3
I wont be using the GTX480 blocks yet until i finalise what rads im going to need,so if i take out the price (for now) of the GTX480 blocks (which have cost the most up to yet) the total price stands @ £38
So it looks like i am definatly in with a chance of building a custom kit cheaper than a pre-built unit.
I will update once i have sourced some rads (as cheap as possible i might add
) andgot my new case the Fractal Arc Midi when its available.
Here is a pic of a few of the bits i have sourced so far :
Silver Kill Coil
) andgot my new case the Fractal Arc Midi when its available.Here is a pic of a few of the bits i have sourced so far :
