Is that how it works? I've played DX9 games on a DX8 card, doesn't it just use a lower version? And aren't there often options to use OpenGL?
well then if this is true they should have supported dx10/11 into XP then instead of trying to 'bully' users into upgrading, its typical bill gates moaning he dosn't have enough money as usual
and remember that 'windows' is only a software interface so using XP does not mean you have a '10 year old system' its all about the hardware (and if your graphics card supports DX10)
I'm stubborn though! I bet someone will get it to work on XP.
I thought we all new that Battlefield 3 was gonna be DX10/11 from pretty much when the game was announced. So why the be uproar now?![]()
Hasn't been confirmed yet, but rumour is no XP support for BF3.
http://fudzilla.com/games/item/23379-no-xp-support-for-battlefield-3
"lol no dx11" sums it up nicely
Ignore list, hooooooooo!
Have a glance at the consoles, then back to PC hardware.
The Xbox360 has a DX10 GPU and the PS3 has a DX9 GPU
Now to PC hardware,
http://store.steampowered.com/hwsurvey
70% of gamers have at least a DX10 capable graphics card, which means that 30% won't be able to run BF3 due to being limited to DX9 (and granted, those DX9 cards wouldn't be much fun to play on)
But let me put it another way, that graphics card you bought in 2006, such as a GTX 7800, is no longer supported, whereas, on the PS3 - which has a very similar chipset directly based on a 7800 - will be supported.
For arguments sake, you might as well be complaining to PS3 owners for holding onto such ancient hardware. Why should support for a PC system on a similar spec to the PS3 be suddenly dropped, alienating 30% of potential gamers? Surely if it can run on a PS3 it can run with the bells and whistles turned down on a 5 year old rig with a high end GPU from that era.
The money comes from consoles, which means that they have to cater for the ageing hardware there, and the DX9 chipset on the PS3.
If the PS3 is running DX9 hardware, then I'm going to assume DX9 will be supported in the PC.
How can I get to ignore idiots like that! were is the option ?
i understand and i have already said i will be using windows 7 for bf3
some people .
i understand the differences i have w7 for like 100000 time i just prefer xp. reel your neck in for a minute you might see that![]()
Click name, view profile
Click 'User Lists' under name in said profile, add to ignore.
